rhagfo wrote:
goducks10 wrote:
Here's a few
http://www.forestriverinc.com/FifthWheels/WildcatWest/default.aspx?model=wildor&page=floorplandetails&floorplanid=4741&RVType=fifthwheels
http://www.heartlandrvs.com/index.php?p=35&c=midprofile&sc=SD&i=SD+2880+RLT&view=floorplans&fcmd=showfplan
http://www.openrangerv.com/roamer/fifth-wheel-floorplans.php
http://www.forestriverinc.com/FifthWheels/Silverback/default.aspx?page=floorplandetails&floorplanid=3199
GoDucks, that list has three with a GVWR of 13,000#+! You will get many that will say that is getting to 350/3500 SRW territory, if the GVWR of the TV is 10,000# they will be close to the numbers, maybe even slightly over.
I tow a 12,360# GVWR 5er with a 2500 without issue, but that is me and not a recommendation.
GVWR's are only good for figuring CCC. Dry weight is what is important. The 282RK for example has a dry weight of 8509lbs with a CCC of 4946lbs. Do you really think someone will load 4946lbs in a smaller 5'er? The Sundance has a 4050lb CC, the Silverback has 3825lbs of CCC. Most people load 1000-1500lbs in their trailer. The OP was looking for 5'ers under 10,000lbs dry.
