smarty's avatar
smarty
Explorer II
Oct 01, 2018
fixing slide out
Have a bedroom slide that I need to change electric motor on. System is Swintec. Bedroom slide is all the way in and I need to get it partially out to remove motor. Unplugged motors from controller but slide will not move. How do I get the slide out so I can get to the retainer screw in the motor?
Thanks in advance
Rig is a 2015 Tesla T3212
  • You may have a pin you can pull to delink the motor. For all the troubles slides present they just aren't worth it.
  • Plug the motors back in find the controller hit the small black button on the controller for a few seconds this overrides the system then you can move it out
  • There is usually a manual crank position somewhere to crank out the slide. It would help if you would post the make and model of your rig so members could help you out better. Just click "edit" on your post to add that information if you can.
    Barney
