Whiskey_River
Feb 15, 2018Explorer
If it is just the fresh water tank, I would give the Phil Swift tape a shot. If it does not work, you will just be dripping fresh water and not stinking up the place with grey or black water....
I cracked my grey water tank at the neck of the tank trying to get the valve out to replace it. I sanded the neck and roughed it up as best I could, then wrapped it with fiberglass cloth, and smeared epoxy all over it. The epoxy you get with the plunger that disperses the same amount and mix it and smear it on. Has not leaked in 2 years..
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
