Rod_Wise
Aug 05, 2013Explorer
I just fixed the same problem on my fiver. Just do a search on the RV message boards for the details. Basically remove tank and clean it out good; check o-ring and replace if needed (my looked good -- so reused it); put a bead of Permatex RTV silicone around the oring and around inside seal area of the tank and put back together. IMPORTANT: let set at least 36 hrs before filling with fluid. Good Luck
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
