greyram10ExplorerAug 04, 2013Fluid Leak at Slide-Out ReservoirI'm experiencing an oil leak at the base of my 5th wheel slide-out reservoir. It appears even without moving the "Slide" in or out. Has anyone had this problem or know how to fix the leak?
jdogExplorerAug 06, 2013When mine leaked, I found out the fittings were loose, was not leaking from the fluid tank as it appeared to be.
