azjeffh
Nov 20, 2015Explorer
laknox wrote:
The truck's payload is based on a stripped, 2wd, gasser, single cab, with no options. With a 21k GVW on the FW, you're solid into a 450, or bigger, truck; again, IMO.
Lyle
Actually Lyle the payload listed is for a Crew Cab 172.4" wheelbase. However you do bring up a good point, can't tell if it's a gasser or diesel as they make 14K GVWR in both. However the gasser only has a GCWR of 22800 max so I had assumed the larger payload would have been for the diesel. Could be my bad.
As mentioned, with the F450 having a payload of 5300 (per specs) I don't see how that helps me.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
