In response to your post Denny, I felt that in order to get a true measurement of deflection, I needed to have solid points. Once you raise the pin to get the landing gear off the ground, without blocking, you get extra weight on the springs causing the trailer to move lower at the axles, so the geometry changes. I suppose, I could have blocked it just in front of the axles rather than blocking mid-way the axles and the deflection would have been marginally less. In any case, I think fixed points give you a better idea.
Today, I dropped the fascia to get a good look at the pin box, welds and structural members that the pin box is attached to. Very little movement there when I move the pin up and down and all the welds look sound. No blocking this time, I jack the pin 1 3/8 to get the landing gear off the ground. Now I do another experiment and raise the landing gear to get the pin off the jack. To do this, I raise the landing gear 3/4 inch. This tells me that half the problem is between landing gear and pin and the other half between landing gear and rear axle. I am coming to the conclusion that everything is intact, but that the structure is not built solidly enough. I am also coming to the conclusion that it has always been like this, although maybe not quite as severe.
Makes me wonder how many rvs there are with inadequate frames.
One thing I want to do before I conclude this lengthy post and that is to blast Lippert. Almost all the problems I have had with this trailer have had to do with Lippert. Broken shock mounts, uneven tire wear and a flimsy frame. My axle issues started with uneven tire wear. First I was told by the dealer it was the affected tires, and then he replaced them. Finally just before the expiration of the 2 year warranty, it was determined that it was an out of spec axle and it was replaced under warranty by another rv dealer. Then they couldn't get adequate money from Lippert so they came after me for the balance. Fortunately, Crossroads came through for me. After all this, the uneven tire wear problem was not solved. Took it to a truck alignment shop and for $100 my problem was finally sold. Anybody out there wanting to buy a new trailer, do yourself a favor and check who the manufacturer of the frame and axles is. I don't understand that there isn't more quality control. It's like building a nice home on a crappy foundation. That's my rant for now.
