Old-Biscuit
Jul 21, 2014Explorer III
Valve next to pump...........?
Typically there are no shut off valves for the pump. Water Heater yes..pump no.
And pump can run dry without harm..they are diaphragm pumps and only move about 1/8"
You probably have a Shurflo Classic (model 2008) as it is the one mostly used by OEM. That pump has been phased out.....parts still available (Check valve 94-237-00..about $12)
You could also just install a 1/2" in-line check valve in pump suction or discharge line. Shurflo has one......#340-001
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
