lynndiwagon
Jul 21, 2014Explorer
Yep, check valve in pump is leaking. Just went through this. Go to Camping World and buy 1/2" check valve. Go to Home Depot or Lowes and buy the flexible 1/2" to 1/2" flexible line. Unscrew the 1/2" connection from the pump outlet and screw on one end of the flexible line, screw the other end of the flexible line to the check valve (with arrow pointing away from the pump) then screw the line that you took off of the pump to the other end of the check valve. Confusing? This will work.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
