RustyJC
May 06, 2015Explorer
atxshaws wrote:
You know the city water connection check valve sprayed me the other day when unhooking. Bet it is the cause.
If you were running the water pump, then the city water check valve might be bad and result in your getting sprayed. Failure of the city water check valve wouldn't fill the water tank, though - only the check valve in the water pump/fresh water tank line could cause that.
Rusty
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
