Baja_Man's avatar
Baja_Man
Fresh water tank oveflow lines will not stop leaking
First time i used this new to me TH. 2009 Tahoe (MVP) 284 SA. Filled 100 gal freshwater tanks ( 2 serparate 50 gal tanks that fill through one fill location. I filled tanks until water came out overfllow lines. Each tank has one line. These overflow lines are flat flimsy rubber lines, not round plastic / rubber lines. They appear to be mounted at top of tank and simply drape over and hang down to bottom of tank.
Since I left house and while camping, one of these overflow hoses continues to drip water. It will not stop. I thought after a few gallons were used it woiuld stop leaking water.....it has not. After 24 hours, my water tanks and at 1/3 full with not too much use. I’m losing water as I camp!!!
Why is this happening?
Any clues, insight, advice on what to check and how to check?
Thanks!
  • If siphoning, that woulsd indicate overflow line goes to bottom of tank (inside tank)....???
  • Sounds like the overflow in the tank extends to the bottom of the tank and the tank is siphoning out. If so install a vacuum break.
