donpop
Jun 24, 2014Explorer
Fresh Water Tank Sensor
My fresh water tank sensors have always worked fine but this weekend it read empty even though I had filled it before leaving home. I hooked up the hose and it took very little water to fill the tank. Today I took the cover off the command center, moved all the wires and cleaned a little dust off the board but nothing changed the reading. My tank is at the rear of the trailer and the galvanized panel cannot be removed due to stabilizers and a factory welded trailer hitch going from frame to frame. We only take the trailer to a country place that has a water system so we will always have water available but it will be a little unhandy not knowing when it is getting low and need to have some added.
All the water level lights flash quickly when the button is pushed but then it only shows empty. Anyone have any suggestions over what I have already done? Thanks Don
