SDcampowneroper
Jan 17, 2018Explorer
You need to block the louvers on the outside lower fridge vent. Foam pipe insulation is ideal. No need to place a light bulb, not enough heat anyway as cold as you are in.
Place a remote thermometer that you can monitor inside against the outside wall above the vent door, adjust blocking of the louvers to maintain temps there above freezing, below summertime Its Hot!
Pianotuna, Bobs your Uncle & I have been there!
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
