Old-Biscuit
Mar 29, 2016Explorer III
Roughly same amount due to -equalizer- that connects the 2 axles leaf springs in the center.
So 5000# each......but rear can have slightly more weight if 5vr is nose high or front can have slightly more weight if 5vr is nose low or tanks are forward of front axle.
Side to side can have different weights on same axle due to components inside 5vr.
so 5000# on axle could be 2700# one side and 2300# other side
Weight will only give you TOTAL weight on axles (combined) unless you have individual position weighing done
But any weighing is better than none!!!!
About Fifth Wheel Group
