valhalla360
Mar 31, 2016Navigator
phillyg wrote:
Wait a minute! If the known weight of the FW is 10,000lbs and the known pin weight is 2,000lbs, isn't each axle at 4,000lbs, give or take a few pounds? Am I missing something here?
It's typically assumed (right or wrong) that the manufacturer set up the trailer axles to handle the expected trailer weight.
Therefore the reasonable assumption is the OP was asking about the truck axles as the manufacturer doesn't know what trailer you are planning to tow.
You are correct about the trailer axle weights.
About Fifth Wheel Group
