pjtracer's avatar
pjtracer
Front Cap Cleaning
First time fifth wheel owner. I bought a 2011 Copper Canyon. I am sure it sat outside for 3 years. I have washed & waxed it & it looks great except for the front. The front does not appear to be fiberglass & looks like plastic? The decals are fine but the plastic cap just does not look clean. I can rub it with my fingernail after washing & remove the dinginess down to a clean white. I have scrubbed & used several soaps & still can't get it off. I used Meguiars cleaner wax & the marine wax. It shines it but does not remove the dinginess or grime. Anyone have an idea what I can do to clean this before I wax it?
  • I am surprised the Meguiars did not help since I believe it contains a petroleum distillate. That will usually cut through grease based dirt.
    A couple of cheap things to try would be lighter fluid/charcoal lighter/kerosene/diesel oil (whichever you have handy). Or, if that does not sound like something you want to try, go to a Dollar Tree store and buy their de-greaser for $1.
    If it is somehow minerals or chemicals from the rain, try a little vinegar.
    You could also try a Meguiar polishing compound. I saw a guy mix equal parts of Meguiar's cleaning wax and polishing compound that he applied with an ordinary (not high speed) buffing wheel. It did a heck of a job in one step.
    Just some thoughts off the top of my head.
    Let us know what finally does the trick.
  • With your vin, bet you can call the mfg. or go online to their website and they may be able to give you the info 'straight from the horses mouth' :) :)
    With a new toy, always good to snoop around the mfg web site to see what you can find to help with your ownership experience !
    Is this your rv?
    others will be along to help with your particular model's finish type as I don't know it :) good luck !
