Whiskey_River
Jun 23, 2019Explorer
OK thanks everyone, it appears the general consensus is legs & not the motor. I will take off the cap & check next week end.
I know both legs should run at the same speed & they did for years. I also can sit on the ground & press the extend switch & visually watch the left (drivers side extend faster than the other side.
And one side is not cranked up higher than the other side. I have the top marked with a sharpie on both sides.
As I said in the original post the opposite happens when lifting or retracting the legs. The right side gets to the top, ie the sharpie mark and I stop as don't want to over run that side and the left side is still 2"-3" from reaching the sharpie mark. I then disconnect the square rod and roll the left side up to the sharpie mark. So when starting to extend the legs they are both at the same starting point. And I put the legs both down 5 or 6 holes (both the same on the drop down before starting the power.
I know this makes no sense but you can't make this up.
I'm not an RV tech but have always done my own work. Some being installed a wet bolt system, repack wheel brgs every couple years, installed 2nd A/C in bedroom, toilet gaskets & other stuff. This has me baffled…...
About Fifth Wheel Group
