B_O__Plenty
Jun 24, 2019Explorer II
fj12ryder wrote:I got the wrong size leg when I ordered them. Just welded on a new tab and it worked perfectly.Njmurvin wrote:You most like could have gotten by with welding on new tabs on each leg to properly support the leg and work with the positioning of your brackets. That would have been much easier than taking off the old brackets.
I think this is the perfect excuse for getting a dual motor setup. My single motor setup is marginal. I have to lube it at the beginning of each season. Be careful about which dual motor setup you buy. Carefully measure the distance between your frame brackets. Some may fit your existing frame brackets and some may not. Unfortunately mine don't fit either of the major aftermarket kits. To use one of those kits, I would have to cut off my old brackets and weld on new ones in different positions.
B.O.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 24, 2026
