valhalla360
Jun 25, 2019Navigator
cummins2014 wrote:honda1 wrote:
roll pin sheared at one of the top bevaled gears .
Wouldn't that just put a stop to it, no movement at all ??
I suppose it's possible the gear has broken free from the shaft (shear pin failed?) but there is a little friction still directly between the gear and the shaft.
So when the good leg lifts the front enough that there is no pressure on the bad leg, it is able to turn the shaft but this doesn't happen until the good leg is extended a few inches more.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
