slomark wrote:
If Venture is the manufacturer, give a call and they'll pdf the maintenance instructions.
Quote from my Venture Landing Gear Owners Manual
Venture landing gear is lifetime lubricated and should never require maintenance.But as I posted...I spray the inner/outer tubes and have dropped a dollop of grease on top of bevel gear under the cover.
I really don't think 'lifetime lube' cuts it. The jack screw does not get any additional lube unless modifications to tube have been done......drilling a hole to squirt lube in or add a jerk fitting.
DO you have something different from Venture as to lubing?
