Chuck_thehammer
Mar 28, 2017Explorer
Old-Biscuit wrote:
Typical 2 stage LP Regulator has a 160,000btu flow rating
The GREEN ACME nut on pigtail hoses have a 200,000btu flow rating
LP Regulator should be preset for 11" WC (roughly 0.4 psi)
IF pressure to high then furnace COULD overfire/overheat
BUT same problem would be with water heater, fridge and stove top burners.
Airflow........Obstructions (Usual cause)
Thank You Sir,
will do cleaning and inspection.. when I get home..
only Furnace has issue.. right after regulator replacement...
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
