slapshot12
May 03, 2018Explorer
I just installed the Furrion. My Momentum came pre-wired for it, so the install was easy. I found the camera was wired from the factory so it was always on, so I rewired it to a running light so I can control it. I hard wired the monitor power to an up fitter switch on my F-350.
With the trailer hooked up in the driveway, I have 2 bars of signal strength. The picture is a little wider view than I'd like, but it'll work ok. It was paired already, so I just ran through the setting real quick and it was working in less than 5 minutes.
If you do have signal issues, you can replace the antenna with slightly taller one.
About Fifth Wheel Group
