ksss
Apr 14, 2014Explorer
Having the garage loaded and full water will help. The water tank is directly under the garage. That is at least a counterweight of 800-900 pounds, plus whatever is in the garage. I will say that I have a 342 that I pull with the 3500 in my signature. That 342 is heavy, it settles my DRW more so than did the 322 that I had before. If your 331 weighs up like my 342 (they are much the same trailer I think, you will be overweight. You certainly will want to use Timbrens or airbags to level it. That wont solve the weight issue however as I am sure that you will still be heavy. You could run it empty and weigh it and then load it up and see what the difference is. I would be interested myself in seeing what the difference is.
The 3500 SRW also has larger tires.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
