- The_real_wild1ExplorerWhat is the towing capacity of the truck? You didn't say what year it is. Also there should be a decal on the trailer as to the empty weight and the max weight. I came close to buying a 3/4t chev but after checking my weights I found the 2500 was too light. Bought the 3500 srw and I'm good to go. What are you going to haul in the back of the trailer? If you are planning on a few chairs and maybe mountain bikes vs a sxs there is a big difference in the extra weight.
- tinner12002Explorer
burningman wrote:
The truck can handle it, as mentioned the difference between a 3/4 ton and a one ton is virtually nothing. You'll want some springs or air bags, I prefer bags because I use my truck all the time not just hauling heavy and I don't want to ride around in a stiff truck when it doesn't need to be. Overly stiff empty pickups get downright dangerous at even moderate speed on bumpy surfaces.
It's all about the wheels and tires. You're in the territory of either 19.5s or duals.
The rear axle rating on the sticker assumes stock wheels and tires, which are the main limiting factor. The axle itself is good for a lot more and it's the same parts that are in the dually axles.
The 3/4 ton axle is NOT the same as a 1 ton dually! Using 19.5 tires on a 3/4 or 1 ton requires either all brand new wheels and of course tires, which aren't cheap or using adapters from 8 lug to 10 lug wheels. If you think the difference between a 3/4 and a 1 ton is virtually nothing you best do some more research! - burningmanExplorer IIThe truck can handle it, as mentioned the difference between a 3/4 ton and a one ton is virtually nothing. You'll want some springs or air bags, I prefer bags because I use my truck all the time not just hauling heavy and I don't want to ride around in a stiff truck when it doesn't need to be. Overly stiff empty pickups get downright dangerous at even moderate speed on bumpy surfaces.
The rear axle rating on the sticker assumes stock wheels and tires, which are the main limiting factor. The axle itself is good for a lot more and it's the same parts that are in the dually axles. - slapshot12ExplorerI'm fairly certain you will be waaaaaay over the cargo capacity with that pin weight. My truck, '15 F250 listed in my sig, has a cargo capacity in the 2200 range according to the yellow door jam sticker IIRC. I can't even be legal with the 35-36' TH I'm looking at with a 2300-2600 pin weight and 12k-12.5k empty weight. I have the 10K gvw option and airbags. I'm certain it'll tow either 5th wheel TH I want just fine. With the Harley or atv's loaded, it'll drop the pin weight by around 200#, so I'd only be a few hundred pounds over weight. But, that's still overweight. I need to weigh the truck and get exact numbers before I even seriously consider a 5er. I should have bought a 350 srw.
Most of to 40-42' TH I've looked at have a 3500-4500 pin weight. I your cargo limit is near mine, you could be 1500-2500 over weight. I'd probably be willing to gamble with my numbers, but wouldn't even consider towing a 42' with a 250. Like others said, I'd be going with a 350 drw at a minimum, if not a 450. - mkirschNomad IIWhy? Maybe because his personal preference is to have some cushion as far as capacities go, and not be right at the maximums, and not need aftermarket suspension helpers to correct bad conditions?
- Cummins12V98Explorer III
coolbreeze01 wrote:
clemp wrote:
Just purchased a F250 Diesel, then I bought 42ft Road warrior, I'm thinking I can't haul it with that truck. Any thoughts
I'd be looking at 4500 and 5500's. Good luck.......
Please explain why?
My 41' MS weighs 23K. It places 5,800# on the truck. I am within trucks axle ratings and combined towing with 15 RAM 3500 Dually. Towed all over the West in all conditions with a very stable towing experience.
- goducks10ExplorerJust do like they do here in Oregon. Put a lift kit on the F250, load your sand toys in and head to the beach. Should be fine :E
- coolbreeze01Explorer
I'd be looking at 4500 and 5500's. Good luck....... - N-TroubleExplorerDefinitely dually territory...
Bet the salesman said you would be fine though right? - BedlamModerator
Cummins12V98 wrote:
Bags and 19'5's "it will tow just fine". ;)
I'll agree with the 19.5" tires and rims but would suggest replacing your rear suspension with heavier spring packs before going to bags. The OEM wheels and springs are selected for a 6000-7000 lb rear axle weight - The axle, frame and powerplant have sufficient capacity, but the wheels and suspension do not. If your state licenses by GVWR or GCWR, make sure you are paying for sufficient capacity.
If you are in one of the states or provinces where the GVWR tag is absolute, you only have the option to upgrade the truck, downgrade the toy hauler or move.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
