beachbum5
Mar 15, 2015Explorer
Gas VS Diesel F250
I am looking at new F250, I have f wheel about 8000lbs. I would like to know gas mileage while towing and not towing, also on diesel. How would gas handle the load?
Thanks
Thanks
spud1957 wrote:rhagfo wrote:spud1957 wrote:
Seems a lot of talk about the gasser's "redline" needed to go up some steep grades. The 6.2's redline in 6000. Way above HP and torque. Absolutely no reason to go that high.
In another thread there is picture posted by a strong diesel proponent of his dash showing pulling a grade at 60mph. What the picture also shows MPG at about 4 AND 3000 rpms which is 500 rpms below his redline. So, a diesel roaring up a hill just below his redline is OK and isn't as loud as a gasser?
Maybe the fact that he is climbing a 6% grade running 29,000# GCW and still able to go 60 should be why diesel owners smile.
I believe that he was showing 2.800 rpm, which is about 80% of red line. If a 6,000 rpm red line gaser it could only turn 4,800 rpm and with trying to 29,000# would not likely happen at 60 mph.
My point is not a 6.2 pulling GCWR of 29,000lbs. That's ludicrous. The diesel is pulling a 6% grade at less than his rated GCWR and he is at 80% of his redline. If I had a GCWR of 29K, I too would have a diesel.
I am almost at 90% of my GCWR and I too can pull a 6% grade at 60 MPH and do it at 4000 RPMs or 66% of my redline.
So for diesel owners mocking gassers that they have to pull 6% grades at redline is not completely accurate and also a bit hypocritical.
wing_zealot wrote:
Now I expect to hear about how you passed 12 gassers sitting beside the road in the mountains. More rhetoric, when facts are scarce.
