theoldwizard1
Jul 19, 2018Explorer II
valhalla360 wrote:Tvov wrote:As long as you don't try to start both air/con simultaneously, paired 2000w units likely will do it but you are still pushing them really hard. I would want 5-6k watts of generator.
Just curious... if the issue is "start up surge", switch the AC to manual (if possible) and start them separately -- start one AC, then a few minutes later start the other one?
Add soft start to both, don't start at the same time and don't use the microwave without turning off one A/C unit.
Champion does make 3500W and 4000W (starting) inverter generators, 95 lbs and 82 lbs respectively. YouTube review of 4000W inverter generator.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
