95jersey's avatar
95jersey
Generator sizing issues?
I have a 2017 Jayco 273 Toy Hauler (30 amp) with a single 13,500 BTU AC (according to their website). It has gas/electric water heater and fridge, micro, 2 (TV's), digital antenna, stereo and LED lights.
I occasionally dry camp and use my Harbor Freight Generator (4000/3200) to run the AC and assorted electronics (water pump, TV, stereo). I try to run the water heater and fridge on gas during these trips. Please no inverter recommendations, not interested in spending the money at this point.
I have run the generator right from the RV power cord as well as tried extension cords (10 guage) to run the generator further from the camper, with mixed success.
With the extension cord, the generator will overload occasionally and "pop the breaker" with the AC on. I have to go outside and reset the fuse. Sometimes this rarely happens and sometimes it happens frequently. I don't get why its so haphazard.
If I don't run an extension cord, it is more reliable, but will still occasionally "pop the breaker". I try to only run the minimal while running the AC such as (lights, water pump, maybe stereo/tv).
The manual says 13,500 BTU AC, but there was an optional 15,000 BTU available from the factory. I bought mine used so not sure which one it has. Also, it never "pops" at start up, it is usually when it has been running for a bit. So it seems the generator has enough power to get the AC going without issue. It is just a random breaker pop for no reason. It never pop's the camper fuse, just the generator.
So few questions...
1)why is the fuse popping more often with an extension cord? how long can you run an extension cord and what size to prevent this?
2)do I need to up size my generator to prevent further overloads? or do I have another issue with the RV?
Harbor Freight has a 4250/3500 and 6500/5500 in my budget. I would rather get the 4250/3500 as it is cheaper/smaller and more quiet, but I don't want to buy it and just have the same issue. They have a 6500/5500 for another $90, but it is another 40lbs heavier and 4db louder.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
