hiker108's avatar
hiker108
generator stalls when converter tries to charge battery
I have Yamaha EF2000iSv2 generator.
When RV is hooked up to house A/C and just charging battery (with converter on) my handy dandy watt monitor shows it drawing less than 2 amps.
If I connect RV to generator, I can run lights and heater, etc (approx 6 amps) with battery disconnected. However, if I turn off converter and have battery hooked up, with generator running, it stalls out if I then turn on converter breaker. Watt meter is still showing only 1.6 amps as the generator bogs down and stalls. Weird that this doesn't happen with battery disconnected and OTHER 12 volt stuff turned on!
Any thoughts??
Ed
