Hammerboy
Sep 30, 2016Explorer
Mine don't have the auto level, it was a unit they had in stock. No leaks on the shower or any plumbing for that matter and I do keep an eye on the plumbing for leaks.
The only difference I noticed between the 16' and 17' is that the 17's the basement doors are a little shorter in width (basement is still the same size) and that allows you to open the the basement door without interfering with the entry door if that makes sense. On the other side the shorter (again in width not hieght) you can open it fully without interfering with the bedroom slide. The 16's we saw they had the support arms as it would hit the slide otherwise. To me that's an improvement. I hate it when doors interfere with each other, something we always seemed to have in our previous units. Hope that made sense also
Also I noticed they are starting to add refrigerators to the outside storage compartment that is behind the fireplace. It's seems they pulled the fireplace further into the room to make the compartment deeper.
Dan
Dan
About Fifth Wheel Group
