Arnrod172's avatar
Arnrod172
GFCI or Breaker Location. Help needed!
Howdy y'all!
I just purchased my first RV on 08-02 and I am needing some assistance, so I think I tripped a breaker on the refrigerator for my 3610re big horn. I'm not getting any electricity to the 120vac outlet in the back.
I've troubleshooted by flipping all the breakers in my control panel as well as the 50 amp shore breaker outside off and back on. Reset GFCI breaker in bathroom and I've checked all the fuses as listed in the dometic operator manual and fusebox they all work. I just can't seem to find current to that outlet on the back of the fridge.
Am I missing something? Any and all help is appreciated.
After work I might try to check the outlet wires to make sure they're not fryed.
  • Usually refer circuit is not GFCI protected. Turn the refer breaker off, go out and take the outlet apart. Then using a volt meter check for voltage directly at the wires. If its dead, start tracing wires. If your refer in in a slide out, start at the junction box under the slide out.
  • In addition, the refrigerator works just fine in LP mode. I don't have any problem as far as the refrigerator is concerned.
