Oldtymeflyr
Nov 28, 2013Explorer
I have recently gone from 16" to 17" tires and have found few choices and not necessarily stiffer sidewalls.
The load king between the two is still the 16" tire which I believe will be a stiffer tire. As far as less rubber in the 17" that may be true but you have less capacity so it would seem to be less stiff.
Take a look at the many tire specs available at Tire Rack, it will give you a lot of info into what is out there.
Good Luck!
Good Luck!
About Fifth Wheel Group
