nayther
Jul 16, 2014Explorer
taken wrote:
IMHO, if you've ridden even a short amount of time this should be a non-issue. Riding on as many have said is like riding down your driveway. VERY easy. Backing off is almost as easy just a different process. When backing off have the bike off and in 1st gear. Use the front brake and clutch to slow you down and creep backwards with both feet down. I never even tried to use my back brake as it would take one foot off the ground. The only part that you have to be deliberate and confident about is at the bottom of the ramp. When the back tire is on the ground a couple of feet back from the ramp and the front tire is still up on the ramp, unless you are VERY tall your feet won't be able to touch so you have to just roll through it balanced. Granted it's scary the first time but never again after you succeed.
I concur 100% and will add that with a GW if you use reverse it acts like a brake.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
