anaro's avatar
anaro
good article for 5er newbies
I saw this article titled What to know before you tow a fifth wheel from autoguide.com. As a relative newbie to the 5er world, I thought it would be helpful to newbies considering the move to a 5er. If I had to change one thing it would be to tell people to hook the emergency breakaway cable to the truck bed instead of the hitch.
  • Wished that they would not of started out by saying you could tow a fifth wheel with a F-150 or Ram 1500. Credibility of article declines from that point.
  • Old-Biscuit wrote:
    I've hooked my emergency brake cable to my hitch since...forever.
    Nothing stated about king pin plate height vs hitch plate.
    King pin should be about 1" lower so it slides up hitch plate when hooking up (prevents high hitching)
    Nothing about 'pull test'
    Article is just so-so IMHO
    Hooking the emergency cable to the hitch since... forever does not necessarily make it the correct way to attach, some hitch manufacturers recommend otherwise. Something to consider if the hitch comes loose and remains attached to the king pin ,well the emergency cable remains attached. IMHO towing a 10K plus fifth wheel that the hitch comes loose will go whistling dixie thru a tailgate, especially a louvered fifth wheel tailgate. Many other places to attach the cable, bed rails, truck bed, tailgate etc etc.
  • I've hooked my emergency brake cable to my hitch since...forever.
