Old-Biscuit wrote:
I've hooked my emergency brake cable to my hitch since...forever.
Nothing stated about king pin plate height vs hitch plate.
King pin should be about 1" lower so it slides up hitch plate when hooking up (prevents high hitching)
Nothing about 'pull test'
Article is just so-so IMHO
Hooking the emergency cable to the hitch since... forever does not necessarily make it the correct way to attach, some hitch manufacturers recommend otherwise. Something to consider if the hitch comes loose and remains attached to the king pin ,well the emergency cable remains attached. IMHO towing a 10K plus fifth wheel that the hitch comes loose will go whistling dixie thru a tailgate, especially a louvered fifth wheel tailgate. Many other places to attach the cable, bed rails, truck bed, tailgate etc etc.
