Butch50
Jun 10, 2018Explorer
ChuckSteed wrote:
Don’t know if he has electric or hydraulic. But Inventurento say since his post says he had hydraulic fluid replaced he has HYD system. The exposed piston legs can be wiped with transmission fluid, fork oil, etc. primary thing is to wipe before retracting to remove dirt and dust from surface before retracting inside Assy.......
My bad, you are 100% correct. I'm the one that is having problems understanding the written word. :o
I agree with you he would probably should use auto transmission fluid or some oil to give it a wipe down before retracting them to get any dirt or crud off so it doesn't wreck a seal. For long term extension I would use the CRC that I posted as it will stick to the piston and stay there protecting from rust.
About Fifth Wheel Group
