larry_barnhart
Sep 02, 2014Explorer
SH wrote:
I hope it is not an issue as I just ordered the GY for our Alpenlite which has 6 inch steel rims. The current tires are Freestar and stamped DO NOT MOUNT ON 6.5 RWHEELS. Our previous rig (Big Country) had the GY 614's with 6" rims. But...I do not have a definitive answer to your question! :(
Your alpenlite came with good Year G-159 tires and then the 159's became the G-614 tire so you should be good to go if the wheels are original. You might crawl under the trailer and inspect the welds that hold the outter to the inner parts. Some were welded on 4 areas and some were welded around the circle. The four weld wheels were recalled many years ago. worth a look.
chevman
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
