ford_truck_guy
May 26, 2015Nomad
Specularius wrote:robwhite61 wrote:
Not meaning to hijack, but is changing to a metal valve stem is all that's required to go from an 80 psi rim to a 110psi?
depends on the wheel rating. Some manufacturers put 110 psi rated wheels with 80 psi rubber valve stems when used with a 80 psi rated tire.
My trailer came with E rated tires on rims rated for 110 psi and rubber valve stems rated for 80 also.. When I first made the swap , all i did was replace the valve stem with a metal one..
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
