mrxlh's avatar
mrxlh
GPI EZ-8-RV fuel pump gears
Ordered 2 new sets from GPI for my fuel station pump. Here is the reply I received from GPI.
"Dear Mr. mrxlh
Thank you for your inquiry regarding the EZ-8RV light duty 12 volt petroleum pump. We only offer one gear kit for the EZ-8RV unit, however I think the confusion is we also offer a different gear kit for the EZ-8 which is a different pump.
The gear kit for the EZ-8RV is 137500-12 and sells for $18.00 plus S&H."
After reading several threads on the matter, I figured I would give back a little. They are grey-brownish color, not white. They are .750" wide and the major diameter is 1.630". The pitch diameter is .990". As a reference a person could measure them to determine if they needed to be lapped or some taken off the o.d., or needed replacement if the pitch dia. swelled too large causing tooth bind. Measurements were taken with a digital dial caliper.
