Our gray water tank seems to be clogged up. The galley part had water coming up through the kitchen sink drain. We just figured the tank was full so when we drained the tanks the water was still in th...
We had a Cougar, and the valve handles screwed into place. Basically there was a short 1/4" rod stub on the valve, then an extension that screwed onto the stub with a T-handle on the other end. Is this a new trailer to you? The extended handle may have come detached. Our Cougar, a 2001 27-footer had two grey tanks, one for the the rear galley, and another forward for the shower.
