v2k1966ExplorerJul 06, 2013gray water tankOur gray water tank seems to be clogged up. The galley part had water coming up through the kitchen sink drain. We just figured the tank was full so when we drained the tanks the water was still in th...Show More
BlackSilverExplorerJul 07, 2013Your dealer prolly has 25 in stock. A common problem.The extension joins the valve stub rod with a threaded sleeve (which might still be in place if you look). Easy repair.
Related ContentWater tank won't fillWater pump?Gray Tank Smell (Seriously annoying)Gray Water TankCargo trailer gray water tank mounting
