Our gray water tank seems to be clogged up. The galley part had water coming up through the kitchen sink drain. We just figured the tank was full so when we drained the tanks the water was still in th...
open up that slit and you can see where the handle screws in - also have a sab 318 and have lost that handle a few times - lowes has a threaded rod that fits perfectly and is much less expensive than a rv dealer - if I knew where you were I'd give you one of the 3 spare rods I carry - takes 2 rods and lowes has nuts to connect them - call me 321 446 3207 if you have a question - Bob
