Hideoutrver
Jul 05, 2016Explorer
Gray water tanks
My Hideout has two gray water tanks with one discharge valve. How do they work? Does one tank fill first and then drain into the other tank. Are there two drains leading to the one discharge valve?
Dano1955 wrote:
This is the same for my crusader lite. except that my 2nd gray tank has a BLACK handle.
If there is truly only 1 valve, it means the drain lines are tee'd together somewhere under the coach. Which is fine, because the two tank levels will equalize due to gravity. Nothing wrong with that, and should be very convenient. Usually the plumbing logistics don't allow the manufacturer to do that, so you want to double check and make sure there really is only 1 gray valve.
On my rig, a black and a gray valve are in the utility bay, but a 3rd valve is hidden behind the rear axle. Pain in the rear to get to, and not obvious to find. If yours is like that, and you missed it, you would not be the first to make such a mistake.
