jevanb wrote:
After the first year on crappy brakes I pulled the hubs and their was grease everywhere, I replaced with $20 seals instead of the 5 dollar brand that was installed at the factory. My hubs cannot be over serviced..
This is the single biggest cause of this with axle manufactures cutting costs wherever they can as does every other manufacture.
There are better "double lip", spring reinforced seal-sets available for installation AND there are better quality wheelbearing lubes available that have a higher melt point but the axles manufactures will revert to using the cheaper products every single time.
They will also not train their people to properly "pack" wheel bearings during the build process but simple allow them to pressure feed those hubs after they are completely assembled with a pneumatic grease gun that serves to fill the hub cavity with cold grease that forces it's way out past the rear seal before your new hub has even made one revolution in travel.
In short: your brakes were "sabotaged" before they even left the factory by some kid paid minimum wage during the final assembly process at Lippert or Dexter before the axles were band strapped, palleted together and shipped off to some warehouse for re-distribution.
This whole debacle gets further compounded by 'well meaning' but errant dealer staff again attempting to pressure pump more cold grease into cold hubs as a PDI step.
Disassembly and inspection upon delivery with changeout of the rear seals to better quality double lip spring assisted seals, hand packing of the bearings along with later judicious use of a grease gun on those E-Z-Lube hubs, only after you've warmed your hubs with a few interstate miles to then use a couple of slow strokes only of a hand grease gun that is also room temp warm instead of the gun stored in the bottom cabinet under your rig where it's sat all winter is the protocol that will yield years of reliable brakes and hub service.
