marpel
Jun 02, 2018Explorer
Brake Assembly Installation
Over a year ago I removed and replaced, with new, the four brake assemblies on our two axle travel trailer (unbolted the entire assembly from the axle). I also installed new bearings, races, seals etc.
Prior to doing this, I reviewed a number of videos and the instruction PDF from the Dexter site. The PDF and videos were followed to a "T", including pre-loading the castle nut to 50 ft lbs, backing off then finger tightening etc. I was meticulous about this operation.
Since that time, we only used the trailer for a single 2 wk trip (to/from BC and Colorado - mostly highway driving). Due to circumstance, the trailer has sat in the driveway since then.
In preparation for an upcoming trip (again to Denver), I have removed and inspected all assemblies in prep for re-greasing etc.
On two wheels (coincidently, both on driver's side), I found the cap (thing with the flexible rubber centre) had fallen off and was laying inside the hub-cap. Both castle nuts were very loose and the hubs could be easily moved side to side, although the retainer clip was bent over in the correct position. And there was some dirty water inside the assembly along the spindle. The seals looked to be in good condition and it did not appear as if the water entered from that end. Most of the grease was still red and new looking.
My question is, how can the wheels be found in this shape if proper installation procedures ware followed and, do others simply finger tighten the castle nuts as instructed?? It seems this method can result in the hubs being too loose. Any suggested changes to my method.
Marv
Marv
