- Johno02ExplorerWhich is just about double of a smidgen.
- Johno02Explorera smug is just a bit more than a snich.
- mileshuffExplorerJust a note that if you have a SuperGlide hitch then no disc or grease on plate is needed since there is no movement between the kingpin and hitch plate. Just a light oil to keep things from rusting.
- TakingThe5thExplorer
rhagfo wrote:
Old-Biscuit wrote:
Your choice.....
Teflon plate
Teflon plate with just a smug of grease on king pin/hitch contact points.
Say Old Biscuit, just what unit of measurement is a "Smug"?
Definitions of "Smug" - 1. a quantity of grease such that when it lands on one's clothing one can say "It's only a Smug". 2. A fictitious unit of measure given that the mere mention of grease can sometimes cause clothing stains. - deleted-2ExplorerOur hitch quit clanking after installing a thicker poly-disc on the pin.
Worth the ten bucks for that. - azjeffhExplorerTeflon disc IF your hitch will work with it attached. Since not all do, I'd verify before you buy one.
- rhagfoExplorer III
Old-Biscuit wrote:
Your choice.....
Teflon plate
Say Old Biscuit, just what unit of measurement is a "Smug"? - acampinwegoExplorerThank's! I'll be getting a plate.
- acampinwegoExplorerOld Biscuit,We must have been cut from the same cloth,was out this evening getting the TT ready to go, meet new owner tomorrow,came in and wife informed me I had grease here,there and everywhere in between.She's washing my coat now.
- Old-BiscuitExplorer IIIYour choice.....
Teflon plate
OR
Grease.....which if you are like me means it will get on your shirt sleeves, coat sleeves, pants, in your hair, across your face and that's just putting it on---let alone having to clean it off cause it's full of dirt.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
