jbrack's avatar
jbrack
GVWR and Tongue Weight
Does the tongue weight applied to the fifth wheel hitch reduce the weight of the loaded trailer? In other words, if my loaded trailer weights 12,000 lbs while not attached to my truck but when I hitch up there is 2,000 lbs of tongue weight, is my GVW of the trailer reduced by that 2,000 lbs making it now weigh 10,000 lbs?
  • so what I'm getting at is tire rating. By transferring 2,000 pounds to the king pin I am reducing the weight on the trailer wheels by 2,000 pounds, Correct? or am I not understanding this
  • No, the trailer weight remains 12000lbs.
    There is 10k worth of weight on the axles, and 2k on the pin.
  • No. You are still pulling 12,000lb, 2,000 of which is sitting over the rear axle. This is why payload of the tv becomes important.
