clev
Sep 05, 2016Explorer
GVWR, GCWR, & GVW
Every time that I think I have a handle on these, they seem to explode in my mind. I know what each of the letters stand for, Gross Combined Weight Rating,........etc., and I know what they mean. What...
tinner12002 wrote:wilber1 wrote:
I've never heard the term "towed weight" before but it makes sense that hitch manufacturers would use some combination of towed weight and pin weight in order to rate their hitches.
The placard on my Draw-Tite 16K slider reads, "Max gross trailer weight 16,000 lbs. Max pin weight 4000 lbs." No mention of towed weight.
That's two different things unless your 16000# RV has a pin weight of 4000# then your maxed out on your hitch ratings even though your RV now may only weigh 12000# at the axles, at least that's the way I understand it. The 4000# is still part of your RV and is loaded on your hitch in a pull mode.
