IOWASTROKER
Oct 14, 2013Explorer
Happijac beds
Beds would go up, but not down. Called Marv at Happijac several times. Learned there is a 'brake' on the 12-volt motor that will allow them to come down in order to work on the upper limit switch. His terminology confused me at first, but found the problem. Heartland failed to leave any slack in the two-wire redhead connector and it had simply "vibrated" off the control board box. I replaced it, furnace-taped both redheads and I am "good to go". Easy fix, learned a lot and Marv was very patient with me. THX, Happijac. Good JOB.
