dpgllg's avatar
dpgllg
Hauling generator on upcoming trip
Hello,
First before this starts a war on generators I WILL NOT be using the generator while camping nor will it be used where it will disturb anyone. I do not need generator advice but safe and easy way to transport it.
We will be leaving for an extended trip shortly and I wanted to take my generator with me. My 5th wheel has a 2 inch reciever so I can put on a cargo rack or keep it in bed of truck.The generator weighs just over 100 pounds.
I will need to use it while 5th wheel is hitched so in the bed might make it difficult to get to and start.
Has anyone hauled a generator on a cargo rack behind thier 5th wheel? Has it worked out okay?
I'm just nervous about the rack or generator falling off etc.
Your thoughts?
Dave
  • The weight shouldn’t be a problem out back. Of course the rack needs to be substantial even to hold the weight. The worst thing that happens when on the back is the shaking. Thats how bike racks and stuff get torn off. The weight of what is back there cant be too great for the structure but you want to control the shaking or wiping action. When i hauled bicycles on mine in put a ss loop mount on the back of the FW for bungees along with fastening to the reinforced roof ladder.
    So it has to be bullet proof when its hanging out there. If it falls off and tumbles around it may be trash but more importantly is that it doesn’t kill someone. So after picturing myself talking to a lawyer and sitting in court and having just spent what would probably amount to two new ATVs I put it in the back of the truck. I have a Honda 3000 so its heavy and not getting moved around. I bolted it to the truck bed in front of my hitch. I ran 10 gauge cable from my transfer switch in the basement Up under the overhang and up to the generator Also have about a 25’ extension cord that lets me pull up to the pin box with the front of the truck. That puts the noise away from the truck
    My son uses his honda 3000 handi in his truck bed with a heavy chain and he can start it when standing next to the truck bed. Id look at the genny to see if there is an easy way to get just one bolt to go through the truck bed It takes two people to do it but it also takes two people with tools to remove it. Most of the generators that are stolen are the easiest fruit to pick. Its also good to have anything in the bed well secured so there is less chance of projectiles if in an accident
  • TenOC wrote:
    You may want to this or some other home made modification.
    Reinforce RV bumper
    OP Here,
    My 5th wheel does not have a rear bumper. It has a factory installed reciever for a 2 inch hitch rated at 350 pounds.
    Dave
  • My first question would be are you capable of lifting it in and out of the truck bed? If you can do that and you are concerned about hauling it behind the trailer, put it in the bed of the truck and remove the worry.
    If the generator is too heavy for you to lift that high, put it on the rack and check it often. What is the receiver rated for on the back of the trailer? 100 lbs is really not that much for most of them. Strap it down tight, lock it and cover it so it is out of sight.
