- tinner12002ExplorerI have a friend that went from a class A to a truck and 5th wheel. He loves it! He said he just got tired of constantly putting money into his newer class A for repairs.
- CarolynandBobExplorerWe are full timers. We currently have a class C. We are going to get a 5th wheel shortly. We went back and forth between a DP and a 5th wheel.
We ultimately decided on the 5th wheel because of the layout. We believe you get a better layout with a 5th wheel than a class A. Especially if you compare cost. We were not deciding based on cost. We were deciding on comfort.
Yes a class A is easier to set up and my wife can get up and use the rest room, make a sandwich or get something to drink.
As I said ours came down to comfort. We like the 5th wheels with 3 distinct areas. Living room, Bedroom and kitchen. We are most likely to get the blue Ridge 3888FL. We are only going to drive 4-6 hours at a time and stay a week on average, so a longer set up is ok. If it is raining, we will just wait to set up. We are retired so not in a hurry.
Now if money were the issue then you can get a lot more with a 5th wheel/truck set up. Just based on MSRP (which no one pays). The Blue Ridge is about 86K. Add a 70K truck to pull it and you at around 160K.
Now most of the DP we looked at we would have been about 190K plus a 35K jeep toad. Yes you can get a gasser class A for cheaper.
Everyone has different opinions and needs. The above set up will work best for us. As I said we are retired so that changes some things. We have more time to set up or add additional stops for food or restroom. - buckyExplorer II
lanerd wrote:
Aridon wrote:
No regrets. The living space in the fifth is far superior.
Really.... far superior? Care to explain?
Ron
I think the comment is correct provided you get the correct 5er. The bunk models like ours and most of the toy haulers have terrible layouts for living and kitchen. DW wanted the bunk so the DGBs could come with us. Want to guess how many times that has happened? - msmith1_waExplorerHave you considered a toy hauler motorhome?
- lanerdExplorer II
Ron - rogers81Explorer
Bumpyroad wrote:
rogers81 wrote:
I bought a 3500 Dodge diesel C&C with a tow rating of 18000#. I thought that I would not find a camper to heavy for this truck. The first toy hauler we looked at after buying the truck, had a weight of 20000#. You need to do some shopping to get a safe tow vehicle
was that 20000 weight the actual weight or GVWR? If GVWR it might have worked.
bumpy
No no it wouldn't - AridonExplorerNo regrets. The living space in the fifth is far superior.
- TrackrigExplorer IIWe almost bought a 5th, but got a DP instead. I appreciate it especially when we see people with a 5th pulling in and setting up in the rain. We never get outside, just push the levelers and we're good until the weather improves.
Bill - TxGearheadExplorer IIWe've had them all except a TT. Hard to beat a MH with a Jeep behind it.
- BumpyroadExplorer
bumpy
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
